Log Trucking !
Tonio.
Log Trucking !
Message par Tonio. »
En cherchant un camion Mack CH, de la 1ère Guerre Mondiale, sur la toile, je suis tombé là-dessus : Système D !
Le chemin de bois, descendait de la montagne, sur des dizaines de Kms...!!!
There were several types of roads used in the early days of truck logging. In dry weather a cleared dirt path might suffice. But for year-round travel a more substantial road was needed. Three types of roads were most favored and all were made of wood (See Appendix C). A “cross-plank” road (Figure 1.2) was made of sawn timbers spiked to hewn log stringers. A “fore and aft” pole road was constructed of hemlock poles that were available in the woods. Trucks operating on pole roads were fitted with steel flange wheels (Figure 1.3). For greater permanence in applications where a large volume of logs was to be hauled, a “fore and aft” plank road could also be constructed (Figure 1.1). All used considerable amounts of wood with the fore and aft plank requiring the most; about 160,000 board feet per mile (Knapp 1921). In the early 1920s on good roads with favorable grades, logging trucks traveled at rate of speed of 10 to 12 miles per hour. The maximum haul distance was generally limited to 15 miles (Bryant 1923). A new log truck could be purchased for about $4000 and was expected to last four years (Knapp 1921).
Image Image
Detroit Iron Addict !
darkdog
Re:Log Trucking !
Message par darkdog »
le truc de dingue la premiere photo............ce devais etre geniale de descendre quand il pleuvais sur les rondins de bois,couillut les mecs..........
rolling CUDA drag
dart 1965
Kryss
Re:Log Trucking !
Message par Kryss »
Même pour monter, hein ! :P
On a l'impression de voir de la paille sur les troncs, d'ailleurs... à moins que ce ne soient que les échardes du bois, dues à l'usures des passages successifs...
Ben vous savez, quand on voit comment ils faisaient avant l'automobile, j'suis pas trop étonné en fait.
Bon, là, en dessous, ce sont avec des fromages, mais vous avez tous vus ce genre de grosses luges qui servait à descendre le bois vers la vallée... :S
. Image
Re:Log Trucking !
Kryss écrit:
"Les grandes gueules", avec Bourvil, Lino Ventura, etc...Chef d'oeuvre...! Et la scène avec la "schlitte" (orthographe non garantie...) est un clou du film... :P
