jantes
dartifrice
jantes
Message par dartifrice »
je suis tellement devenu psychoactif et méfiant sur cet entraxe de merde
c'est bien un entraxe en 4 pouces qui vendent sur mopar shop;de?
Wheel, Cragar S/S Super Sport 15 X 7
Bestellnummer: CRR-61754
Wheel 15 X 7 Style: S/S
Wheel, Super Sport, Steel, Chrome, 15 in x 7 in., 5 x 4 in. Bolt Circle, 4 1/8 in. Backspace, Each
Timeless styling from Cragar.
Cragar wheels have been around for decades and still raise eyebrows after all these years. The S/S Super Sport wheels from Cragar have the same classic 5-spoke design (except for 4-lug models) and mirror chrome finish that made them so popular. They feature composite construction consisting of a steel rim mated to an aluminum center. The wheels include the same stylish chrome center cap, and use mag-style lug nuts and washers for mounting. Cragar offers a variety of sizes, including larger-diameter models for today‘s high performance tires and suspensions. The wheels are available in both standard and reverse offset models to fit nearly any combination. Reverse offset wheels have less backspacing and more dish, which may interfere with some brake and wheel opening configurations.
Einzelpreis: 213,49
jeronimo
Re:jantes
Message par jeronimo »
Oui . 5x4 in bolt circle, ca veut dire 5 trous avec un entraxe de 4 in". si tu as des doutes sur les entraxes regarde sur un catalogue summit ou sur leur site , il y a une explication tres clair concernant les bolts pattern, le backspace, l'offset et la facon de mesurer les entraxe.
dartifrice
Re:jantes
je dis ça parce que sur le site cragar je les trouve pas
scoubis
Re:jantes
Message par scoubis »
si ça peut aider [img]http://mopar-owners-club.com/images/fbfiles/images0/diagram.jpg[/img]
  • quand ça fuit pu, ben y a plus d huile !!!!
    Charger 500 1971. 440 ci
    fat boy 1450 2000
